oil pressure switch
Old Feb 12, 2007 | 01:37 AM
Jens17's Avatar
Jens17
Default oil pressure switch
I have a significant oil leak on the back of the engine on the firewall side. Is there a way to tell if it is the oil pressure switch?
Old Feb 12, 2007 | 01:50 PM
das2123's Avatar
das2123
Default RE: oil pressure switch
Commom oil leak locations are:
*Valve cover gasket
*Rear Main Seal
*Oil Sending Unit
*Camshaft Sensor
*Oil pan gasket
*Headgasket
You could use a dye in the oil and try to trace the leak.
