what is going on
Old Feb 15, 2007 | 09:49 AM
zony's Avatar
zony
Default what is going on
im driving on the freeway andthe car stalls. and continues to stall every 15 seconds of driving. and each time it stalls, i have to wait at least 5 minutes before it will start again. so then i decide to drive very slow, and the car drove without stalling for about 5 minutes .which is the time it took for me to get home . my questin is why is it stalling at mild to heavy acceleration. and will drive without stalling if i drive at low acceleration 20 mph i checked the codes and they are 12,17,44,47,72,55
Old Feb 15, 2007 | 12:00 PM
das2123's Avatar
das2123
Default RE: what is going on
The code 72 is for catalytic converter failure. You need to replace it and maybe get your alternator and battery checked while you are at it. Also look at the thermostat and engine coolant temp sensor.
Old Feb 15, 2007 | 10:29 PM
zony's Avatar
zony
i have been drivng the car with the code 72 for some months with no problem . and the coolant sensor was installed last july. and i think the code 47 may be from having my hazzard lights on for some time yesterday. today i started the car ,warmed it up for 5 minutes.and put the car in gear and it stalls and will not start right away. so i have to wait at least 2 minutes for it to start .why wont it start right away after it stalls
Old Feb 16, 2007 | 01:10 AM
das2123's Avatar
das2123
Check the wiring to the downstream O2 sensor. So you know you cat is good? Code 72 is Catalyst efficiency below required level, so it might have been just bad for a long time and now it has crapped out on you.
Old Feb 16, 2007 | 09:01 PM
turbodneonracer96's Avatar
turbodneonracer96
have u gotton the codes erased fromthe system from when u got the temp sensor replaced??
Old Feb 16, 2007 | 09:03 PM
turbodneonracer96
after u relplace everything have the codes erased. if u dont the computer sometimes flashes the same codes after 50 miles of driving. the computer remebers the old problems and thinks there still there.
Old Feb 16, 2007 | 09:06 PM
turbodneonracer96
my dad owns an inspection station and he has problems like this that occur!!
Old Feb 16, 2007 | 09:56 PM
das2123's Avatar
das2123
^^^ You couldn't put all that in one post?
Old Feb 17, 2007 | 02:07 AM
zony's Avatar
zony
when the coolant sensor was replaced the mechanic cleared the codes. and the good thing is that he installed the sensor for a box of duncan donuts and 2 cups of coffe.
Old Feb 17, 2007 | 09:55 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
yeah clog them arteries. . . kinda like your exhaust system is sounds like you have poor flow through your exhaust maybe someone shoved a potato in your tailpipe heh heh
