OBX lsd
Old Feb 15, 2007 | 01:29 PM
spudsterier's Avatar
spudsterier
Default OBX lsd
anyone know of sumone that has one???? is it worth the money????
would it work as good as the quafie???
i would get the quafie, but that is just too much money at this time....or really any time for that matter[&:]
Old Feb 15, 2007 | 01:51 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: OBX lsd
i heard they were both about the same but i dont know never seen any real stats on it
guess it was just manufactured by cheaper labor
Old Feb 15, 2007 | 02:21 PM
das2123's Avatar
das2123
Default RE: OBX lsd
They have their issues:
*Case bolts sometimes arent torqued down all the way.
*Snap ring on axle needs to be removed OR bevel the edges inside the diff to allow use of snap rings (recommended)
*Possible broken spring washers (1-2 known cases)
Old Feb 15, 2007 | 08:03 PM
spudsterier
Default RE: OBX lsd
so would it be worth the money do you think?????
i know i am deffinately gonna need one......the day before my car broke i was doin about 70mph and went to pass a semi truck, so i dropped it into 3rd and as soon as i let out the clutch, the car almost threw me into the ditch....so i wanna find a decent one for cheap...
Old Feb 16, 2007 | 12:58 AM
scramer05's Avatar
scramer05
Default RE: OBX lsd
will this help me fight my torque steer when cornering fast?
Old Feb 16, 2007 | 01:06 AM
das2123's Avatar
das2123
Default RE: OBX lsd
It's probably worth the money, just replace the washers and torque the bolts down correctly. Also, bevel the edges inside the diff to allow use of snap rings.
