installing mirrors
Old Feb 18, 2007 | 12:16 PM
kazper's Avatar
kazper
Default installing mirrors
i need help installing the mirrors i bought they are m3 type mirrors with the turn signal in them. my problem is the instructions are in chinese so i have no idea how to install them someone please help
Old Feb 18, 2007 | 12:18 PM
das2123's Avatar
das2123
Default RE: installing mirrors
https://dodgeforum.com/m_705374/tm.htm
Old Feb 18, 2007 | 02:10 PM
FastNeon84's Avatar
FastNeon84
splice it into the green wire on your signal light.
Old Feb 18, 2007 | 07:53 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
what you cant read chineese?. . . JK if i do recall you have to pull the doorpannel off and there are 3 bolts you remove
Old Feb 19, 2007 | 03:13 AM
FastNeon84's Avatar
FastNeon84
ORIGINAL: DOHCgarrett t3
nah....just the little platic piece that covers the bolts...
Old Feb 19, 2007 | 11:26 AM
das2123's Avatar
das2123
ORIGINAL: FastNeon84
But that piece slides under the door panel, doesn't it?
Old Feb 19, 2007 | 03:41 PM
FastNeon84's Avatar
FastNeon84
ORIGINAL: das2123
yea, it does but if you pop it out from the top then slide it out you wont have to remove the door panel....at least for me...i used to always go through that every time i lift my doors up the wire gets disconnected and i had to keep going back and connecting it again...and again[:@]...but i extended the wires now so i have no problem now.
