motor mounts
Old Feb 19, 2007 | 05:36 AM
loud99R/T's Avatar
loud99R/T
Default motor mounts
My front mount is pretty much ripped in half so i guess its time for some new ones i was thinking prothanes frorm modern. I was just wondering how hard it is to switch themand what i all need as far as tools. thanks guys - Koepp -
Old Feb 19, 2007 | 11:39 AM
das2123's Avatar
das2123
Default RE: motor mounts
The prothane mounts are inserts, not a replacement mount. You will need to get a new or used one and then install the mount.
They are easy to install though. Just need a jack to support the engine when you remove each mount.
Old Feb 19, 2007 | 01:56 PM
tranyinstaller's Avatar
tranyinstaller
i saw them do this in scc magazine but i dont know anyone who has done it themselves. they filled all the gaps in the mount with an anarobic sealer ( window sealer, thick rubbery black stuff) i know that would work at least for a while to stiffen the dampening force... but i cant help but wonder how long that would last. but that would be the same case as with the inserts, you would want a new mount to do it to.
Old Feb 19, 2007 | 02:55 PM
loud99R/T's Avatar
loud99R/T
yea i noticed that after i looked right above them on moderns page. but thanks anyways guys i think i will prolly just order the new front one and the inserts aswell
Old Feb 19, 2007 | 07:22 PM
QuiK615's Avatar
QuiK615
stiffer mounts will make your car quicker correct? my friend said you could drill a hole in them and fill the hole with JB weld and it'll help you get off the line quicker[sm=gears.gif]
Old Feb 19, 2007 | 07:27 PM
das2123's Avatar
das2123
They don't make your car quicker, but help eliminate wheel hop, which in turn helps lauches during a race. The stock mounts are soft so that the engine can move and you don't feel the vibration on the inside of the car. But when you stiffen up the motor mounts, the engine will vibrate the car more. So it depends on how much vibration each person can live with as a daily driver.
I haven't heard of JB weld. But drill a hole where?
Old Feb 19, 2007 | 07:35 PM
johnneon's Avatar
johnneon
if u change ur mind u can always use hockey pucks,,,,,my front motor mount has hockey pucks in and it does the job well,,just remove the motor mount put a little gas or lighter fluid on it and melt whats left of the rubber and put the hockey pucks in it and drill the hole,,,really simple,,.
Old Feb 19, 2007 | 08:38 PM
QuiK615's Avatar
QuiK615
haha getto
Old Feb 19, 2007 | 08:51 PM
johnneon's Avatar
johnneon
ghettowhat u can ghettoand put ur money where it counts,and besides ide say the pucks work better and its cheaper,its ghetto but it works really well and no1 even knows its pucks.
Old Feb 20, 2007 | 10:46 AM
Durnald_Toad's Avatar
Durnald_Toad
I am getting two new motor mounts today. I ordered the Prothaneinsertsby mistake a few weeks agoand they are being putin the new motor mounts.
Today Also, The Pacesetter header and OBX catback are going on.
Hockey pucks huh ? Cool
