dome light
Old Feb 20, 2007 | 08:47 PM
javon's Avatar
javon
Default dome light
my dome light does net come on when i open the door i dont know if the bulb is blew or what fuse should i replace and my one of my turn signals blinks real fast and my brake light does not come i tried replacing the bulb and it still does not come on why is my front turn signal blinking fast
Old Feb 20, 2007 | 09:11 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: dome light
does the dome like work when you open any other door? if not try wiggling the door switches in the frameor like you said its prolly the fuse or bulb there should be i diagram on the inside of the fuse panel door or kinda labled on the box itself dont know havent looked at it in awhile . . . havent been home in a year or so.
your front turn signal flasher may be going bad. it is also in the fuse pannel Im not 100 percent sure about it but its my best guess
Old Feb 21, 2007 | 09:24 PM
prplhaze's Avatar
prplhaze
So...you dont have any brake lights right now.? Your turn signal is going fast because you probably have a bulb out.Check to make sure front and back turn signals both working, replace whatever one is not.
As dohc said, does your dome light come on when you open other doors.? If it does, then its the little button that the door hits when it closes, try spraying it with wd-40 and working it in and out a bunch.
Old Feb 22, 2007 | 02:31 AM
javon's Avatar
javon
ok thanks guys my bck bulbs were blew when i replaced them it fixed everything but now when i put my dome light bulb in it stays on even with the door shut or when the car is off how do i get it to cut of when i close my door
Old Feb 22, 2007 | 03:01 AM
iwalton63's Avatar
iwalton63
to get it to shut off when the door is shut, try turning your headlight switch to the right.
Old Feb 22, 2007 | 11:10 PM
javon's Avatar
javon
so is it supposed to be on all the time
Old Feb 23, 2007 | 04:09 AM
iwalton63's Avatar
iwalton63
your dome light? no its not.
only when the doors open, or you turn it on( truning your headlight switch to the left till it clicks). but other then that it should be off
