head question
a dohc is a dohc and a sohc is an sohc, only merging the 2 causes problems. However, the computer on the 95 is different as are some(most?/all?) of the sensors, so if the car is a 95, then you should swap the 95 sensors onto that head
it will fit just fine....between the r/t and a regular dohc, there are no engine differences......you will have to use the 95 cam sensor though...and thats the only sensor on the head......
the differences between an r/t and a regular dohc are mostly suspension and available options....pcm's are the same too as long as the regular dohc is a manual(but when switching the heads it doesnt matter)
