Cam a 95
Old Feb 27, 2007 | 04:14 PM
harley k's Avatar
harley k
Default Cam a 95
I have 1995 SOHC Neon and was wondering if there is any way possible to put a new cam in without pulling the head off?
Old Feb 27, 2007 | 05:36 PM
das2123's Avatar
das2123
Default RE: Cam a 95
ORIGINAL: harley k
Yes you can, but you have to take the tranny mount loose, and do the FMM also. You will probably have to jack the driver side of the motor way up to get the cam[/b] out.
Old Feb 27, 2007 | 07:40 PM
spudsterier's Avatar
spudsterier
ORIGINAL: das2123
ORIGINAL: harley k
huh????? take off the vave cover and remove the timing junk....then unbolt....and replace...
unless of course you are referring to the crank
Old Feb 27, 2007 | 07:55 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
ORIGINAL: das2123
ORIGINAL: harley k
Yes you can, but you have to take the tranny mount loose, and do the FMM also. You will probably have to jack the driver side of the motor way up to get the cam out.
Thats another way, but my way, you can just remove the cam gear.
Old Feb 27, 2007 | 09:27 PM
spudsterier
you talking about leaving the gear on the cam????
Old Feb 27, 2007 | 11:16 PM
das2123's Avatar
das2123
Oops...I meant, just remove the cam
