95 sohc oil pan onto a 96 sohc motor
Old Mar 2, 2007 | 11:08 PM
turbodneonracer96's Avatar
turbodneonracer96
Default 95 sohc oil pan onto a 96 sohc motor
Will the 95 oil pan mount up to a 96 motor. I need an exra oil pan for my oil return for my neon!
Old Mar 2, 2007 | 11:10 PM
spudsterier's Avatar
spudsterier
Default RE: 95 sohc oil pan onto a 96 sohc motor
yeah it will work fine
Old Mar 3, 2007 | 12:20 AM
juggalopanther1's Avatar
juggalopanther1
oil pan from 95 will work all the way up to a 99
Old Mar 3, 2007 | 03:16 AM
das2123's Avatar
das2123
If it's a steel pan, you will need the pick-up tube also. It's different than the aluminum pan.
Old Mar 3, 2007 | 02:20 PM
turbodneonracer96
my 96 is steel and my 95 is steel also
Old Mar 3, 2007 | 02:26 PM
spudsterier
then you should be fine
