Recommended code readers for Neon 1995?
Old Mar 5, 2007 | 12:35 AM
  #21
das2123's Avatar
das2123
Default RE: Recommended code readers for Neon 1995?
ORIGINAL: juanbosco
BTW, do you know where I can download the Haynes manual for neon (PDF format)?
www.autozone.com has some good info and how-to's on their website as well as others.
ORIGINAL: neisg1
I don't know of any such links for manuals. There was a download for a 97 Neon factory manual on this forum but it has now been pulled. I assume due to copy right issues.
You assume correct.
Old Oct 15, 2018 | 07:54 PM
  #22
jetdogy's Avatar
jetdogy
Originally Posted by neisg1
I have a US made, 1995 Neon and have used two different OBDII scanners on it both worked fine. The research I did prior to buying a scanner indicated that 1995 Neons are OBDII compatible, I did not find anything stating any exceptions for those made in Mexico. The current scanner I have is a Toptak TP-100 that I bought new on Ebay for about $65.00us.
As far as laptop adaptors, Google it, there are lots out there. Around $100 and up.
This is just one I ran across.
http://www.obd2allinone.com/
Hi. Do you still have your Neon? I need a scanner for my 1995 Dodge Neon Highline.
Old Oct 16, 2018 | 05:23 PM
  #23
You realize that post was from 2007?
