ok 2nite i was driving home and the light turned red at least minute so i hit my brakes hard......right after hitting my brakes my cae was stuggeling to stay ruuing sooo i pressed the gas and i stay running but had a really bad idle to it like a surge type of idle anybody know the problem?
The brake booster hose hes talking about, is a hose that comes off from your brake master cylinder.(The thing you put brake fluid into).Pinch the hose off when your car is struggling to run, and see if it helps.
ok i think i found the problem.......i think there was alittle watrer in my gas and i got to the fuel in jectors because i just went out and ran my car for like 5min and it ran fine after about 2 min sooo i think the problem is solved thank guys
