timing belt
Timing belt broke going 25 mph. 1997 neon sohv motor. Is there a relatively easy way to check for valve damage. Without pulling the head offf. So I dont waste time or money replacing the timing belt?
honestly the only way to check without removing the head would be to put a new timing belt on the car and then do a compression test......though most likely you will have to replace a few valves....but you might be one of the lucky 2% that dont
Yes there is, remove the valve cover and take off the rocker arms, all the valves are now closed. Then do a cylinder leakage test by pressurizing through the sparkplug holes.
Build one yourself
http://www.xs11.com/tips/misc/misc3.shtml
http://www.650motorcycles.com/LeakDownTester.html
or buy one
http://www.sjdiscounttools.com/atd-5573.html
http://www.justoffbase.co.uk/Cylinde...;category=1817
http://www.spiderautomotive.com/cylleaktes.html
Build one yourself
or buy one
