need help
Old Mar 19, 2007 | 08:28 PM
yakima valleyrcracer's Avatar
Default need help
what one would be the best an acr brake conversion or a srt4 brake system on a 98 neon and what would i need to do either
Old Mar 19, 2007 | 11:52 PM
das2123's Avatar
das2123
Default RE: need help
The 1st gen ACR or R/T rear disc brake swap is much easier than the SRT-4 brake swap.
You will need calipers, rotors, backing plates, brake lines, and e-brake cables. Disc brakes do not add more stopping power over drums, since the rears only do about 15%-20% of the braking. The drum brake setup is actually lighter than the disc brakes, although maintenance is a bit tougher. You DO NOT have to swap your master cylinder either.
Old Mar 20, 2007 | 12:25 AM
spudsterier's Avatar
spudsterier
it has always felt to me that the rear discs work better then the rear drums.....less matnance too
