Well I still have no luck Please help
Old Mar 20, 2007 | 01:53 PM
jnd2970's Avatar
jnd2970
Default Well I still have no luck Please help
Ok the timing belt went out it has been replaced and the water pump. The car ran for 45 min and quit. My dodge dealer has redone the timing belt and replaced the crank and cam shaft sensors. He thinks it is the pcm I bought a used one and it is for a manual mine is an automatic sohc 96 4 door. I plugged in the the new pcm and got the same results: The vehicle gives spark for one rotation and then no spark. If you reset the computer you get the same result single spark first ortation only. No codes.
Old Mar 20, 2007 | 03:14 PM
spudsterier's Avatar
spudsterier
Default RE: Well I still have no luck Please help
even if it doesnt end up being the pcm your still gonna want to put an auto pcm back in there.....otherwise you wont have a torque convertor clutch
Old Mar 20, 2007 | 04:29 PM
jnd2970's Avatar
jnd2970
Ok but what about the spark issue or has nobody ever heard of it?
