wiring
Old Mar 22, 2007 | 12:15 AM
neonracer1010's Avatar
neonracer1010
Default wiring
anyone know where a good place to route amp wiring and 6 disc cd changer wiring and box for it.
Old Mar 22, 2007 | 01:50 AM
das2123's Avatar
das2123
Default RE: wiring
Where is spud when you need him???
Old Mar 22, 2007 | 02:12 AM
FastNeon84's Avatar
FastNeon84
Default RE: wiring
lol....mount the cd changer in your trunk somewhere.....the wiring you can run it under you carpet....and to the battery.....remember to run the power wire through the firewall...not through the fender
Old Mar 22, 2007 | 03:36 AM
93 tona's Avatar
93 tona
Default RE: wiring
i hung my alpine six disc on the roof of the trunk, and if you move your battery to the trunk the amp wiring is a simp
Old Mar 22, 2007 | 03:46 AM
BadBrads97Neon's Avatar
BadBrads97Neon
Default RE: wiring
Ok since I work at Best Buy in the Car Audio Installation section I know the answer to this one lol Mount the CD Changer in your trunk on either side of the trunk. When running your wires always run the power wires on one side of your car and the wires to your stereo on the other. The easiest place to run your wires is under your sidepanels by the doors and then into the stereo and like fastneon said you will always want to run the power to the battery through the firewall. Just find a hole that is already there and is allowing access for other wires and slide the power wire right through. That should work.
