Drivers side brake caliper
Old Mar 22, 2007 | 03:23 PM
97dohc's Avatar
97dohc
Default Drivers side brake caliper
Drivers side brake caliper is hanging up. I replaced the old one yesturday and the new doing the same thing any suggestions?
Old Mar 22, 2007 | 03:48 PM
das2123's Avatar
das2123
Default RE: Drivers side brake caliper
Try this...
Apply the brakes and release, turn the front wheel by hand, open the bleeder screw and turn the wheel again. If it turns again, hydraulic pressure was trapped in the system.
Old Mar 22, 2007 | 06:56 PM
BadBrads97Neon's Avatar
BadBrads97Neon
Das = Genius (Pretty much) haha
Old Mar 23, 2007 | 09:09 PM
97dohc's Avatar
97dohc
I tried what you suggested and it did not work? Any other advice would be appreciated. Also would it make a difference if the vacuum lines are not hooked up? Thank you in advance.
Old Mar 24, 2007 | 01:47 AM
das2123's Avatar
das2123
Check for pinched brake lines.
