Neon looses battery connection
Old Mar 22, 2007 | 07:07 PM
lydo's Avatar
lydo
Default Neon looses battery connection
Hey guys, I have a weird problem here. Sometimes when I start my car, it doesn't stalls on the first crank, then start fine on the second crank. Just like when you disconnect the battery and it has to reprogram. So I'm loosing battery connection. The other reason I know I'm loosing battery is because my radio is deprogrammed so that's the other indication. It's starting to happen more often now, say 3 to 4 times a week. Any ideas what could cause this?
Thanks
Luc
Old Mar 22, 2007 | 08:02 PM
das2123's Avatar
das2123
Default RE: Neon looses battery connection
Loose battery connections and/or corrosion on the terminals.
