glow gauges help
Old Mar 25, 2007 | 03:51 PM
spider886's Avatar
spider886
Default glow gauges help
how in the world do you hookglow gaugesup?i mean i have a ideal but i just wanted to ask b4 i rip my dash apart.
Old Mar 25, 2007 | 07:26 PM
das2123's Avatar
das2123
Default RE: glow gauges help
1. Lift off upper dash by pushing up and popping it off (held on by clips only)
2. Remove 4 screws from gauge cluster and pull out cluster
3. Remove screws to steering column cover (3 on bottom and 1 on the side)
4. Remove screws to steering column liner (2 on the upper area and 1 lower left side)
5. Place new cluster w/gauges into the dash
6. Ground the wire to the bottom of the steering wheel housing.
7. Look at the headlight switch, you will see a yellow wire w/a black tracer. This is the wire you will need to splice into to have the gauges turn on with the headlights.
8. If necessary, unscrew the headlight switch screws to gain easier access to the wires.
9. Put it all together and turn it on. You won't be able to see the lights until it's dark outside
Old Mar 25, 2007 | 08:34 PM
spider886's Avatar
spider886
kool man, thanks
