PCM Help
Old Mar 26, 2007 | 09:42 AM
moretodo's Avatar
moretodo
Default PCM Help
I think that I have seen it in here befor. Can you use a SOHC PCM on a DOHC if year for year.
Old Mar 26, 2007 | 09:51 AM
BadBrads97Neon's Avatar
BadBrads97Neon
Default RE: PCM Help
Got this from another thread:
Swapping between SOHC and DOHC PCM's work, but you get more power from the PCM optimized for you particular engine. Some people like the DOHC PCM in a SOHC car because of the higher rev limiter, which could give you a little more performance.
hope this helps.
Old Mar 26, 2007 | 10:22 AM
spudsterier's Avatar
spudsterier
dohc pcm in a sohc would be alot better then a sohc in a dohc......the car might not run completely properly since it might run a little lean
