regulator
Old Mar 27, 2007 | 09:29 PM
mmench's Avatar
mmench
Default regulator
wat all would be signs that your fuel regulator is goin bad
Old Mar 28, 2007 | 12:21 AM
das2123's Avatar
das2123
Default RE: regulator
Stumbling, missing, low fuel pressure, car not starting.
Old Mar 28, 2007 | 01:04 AM
mmench's Avatar
mmench
thnx . i went to the dealer to order a new one and they were dumb as hell. i had to physically show them the part i wanted before they knew wat it was. also is there supposed to be a ground or sumthing on the regulator? beecause therre is a little tab on the top of it with nothing going to it?
Old Mar 28, 2007 | 10:05 AM
spudsterier's Avatar
spudsterier
that tab is for a ground.....there is supposed to be a ground strap that runs from the tab to a bolt by the e-brake cable....though due to its location, the strap usually rots out pretty fast
