1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
GET low
Old Aug 26, 2010 | 12:50 AM
moparmaniac86's Avatar
moparmaniac86
Default GET low
So i have owned my D150 since i was 17years old. I would like to lower it, i was wondering what are the ways of going about this? i figure for the front you just cut the springs but what do you do for the rear? Any ideas are greatly apreciated!
-Justin
Old Aug 27, 2010 | 06:06 PM
wontacceptthis's Avatar
wontacceptthis
Something about 88-98 chevy shackles brings itself to my memory. I'd imagine you could just flip the axle too.
Old Oct 11, 2010 | 07:09 PM
89dodge150's Avatar
89dodge150
Thumbs up
i was wondering the same thing till i found this....
http://www.airbagit.com/Dodge-Loweri...les-s/1772.htm
Old Oct 13, 2010 | 02:24 AM
moparisthebest's Avatar
moparisthebest
Cutting the springs to lower a truck is a really bad idea, not only will it ride like a log wagon, it will eat tires and make you look like an idiot driving down the road with your front-end looking like this: /-----\ (the outside slashes are your front tires). Drop spindles are the way to go for the front, and flipping the axle over the rear springs are how to do it in the back. You may need to notch stuff in the bed or cut and re-weld the frame in the back depending on how low you want to go. (use blocks in between the rear springs and axle to go as low as you want)
Old Oct 14, 2010 | 07:42 PM
wontacceptthis
****Sarcasm Alert****
Yo homie, dat aint how we do in da hood. Cut dat spring like a gangsta cut everything else. Yo gotta get the demon camber like a GANGSTA FOOL!!! . . . after all, how else are you gonna make a 4600lbs truck with 170 horsepower burn off all four bald superswampers? Name:  mk1cred.jpg
