1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
Need help please!
Old Feb 28, 2012 | 08:27 PM
Tree88's Avatar
Tree88
New Member
Default Need help please!
I have an '89 ram with a 318 tbi. Parked it now it wont start. I have no spark and the injectors are not spraying fuel. I have power to the coil and I replaced the pickup coil still nothing. Truck turns over fine. Really dont have a clue on what it could be. Any help would be greatly appreciated. Thank you.
Old Feb 28, 2012 | 08:34 PM
crazzywolfie's Avatar
crazzywolfie
have you checked the asd? it should most likely be on the drivers side fender. should be second from the front of the truck.
Old Feb 29, 2012 | 02:34 PM
Tree88's Avatar
Tree88
New Member
the asd seems to be working it makes a noise when you turn the key on. On my truck there are only two little boxes on the fender. I think the one towards the front is the one your talking about and it seems to make a couple of movements when I turn on the key. I called the guy I got the truck from and he said itsprobly the computer. He said it probly got moisture in it does that make sense. I dont want to go buy one if its not the problem.
Old Feb 29, 2012 | 02:49 PM
crazzywolfie
i think you may be confusing the noise coming from the starter relay with noise coming from the starter relay. if the asd relay is not working properly you will get no spark or fuel hense why it is called the auto shut down relay(asd for short).
