1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
looking for answers
Old Jun 20, 2012 | 04:52 PM
J.W. COWAN's Avatar
J.W. COWAN
Default looking for answers
i need to know if there are parts available for the 1985 dodge ramcharger
royal se, 318 2 barrel, 2 wheel drive, automatic.
i need the hose extension from the air filter housing to the hose that leads outside for air flow to the air filter. this hose is bolted on one end and small the other end is round and fits another hose that leads outside.
i dont want to change the air flow system if i dont have to but will if i cannot find what i need.
also my lights flicker, radio turns off and back on, i was told to have a load test on the alternator and regulator. the full load test and not the one that just check to see if they work...
could this be the problem that one or both are bad and cause this problem...
Old Jun 20, 2012 | 09:47 PM
crazzywolfie's Avatar
crazzywolfie
i would not worry about that hose. a lot of people usually swap to open element air cleaners. you could get the battery load tested but i would first inspect all the ground connections. corrosion and rust can cause all sorts of problems for the electrical in these older trucks.
