1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
Problem filling up gasoline.
Old Nov 26, 2012 | 02:26 PM
lance25's Avatar
lance25
Default Problem filling up gasoline.
Recently when I fill my gas tank it takes time to fill up after less than a gallon it keeps shutting off telling me already full does anybody knows where to buy charcoal canister.I read about the canister when its dirty one of the cause. Napa and autozone does not carry after market .
Old Nov 26, 2012 | 04:07 PM
SEAL's Avatar
SEAL
A bad charcoal canister won't cause this. It will give off a strong gas smell.
I will bet the little vent tube that runs alongside your larger fill tube is plugged, pinched, or collapsed.
Old Nov 26, 2012 | 06:34 PM
Comrade General's Avatar
Comrade General
It could be the nozzle aswell. That, I would say, is the most likly problem. Try a different station
Old Nov 27, 2012 | 08:28 AM
Scooter78's Avatar
Scooter78
Plus one for both of the above suggestions. I would bet your vent tube is the culprit, but there are a few gas stations that I avoid because I know that my truck and their pumps dont cooporate to get the job done. You dont have a body lift, do you? I have seen that problem a few times on body mount lifted trucks because the filler and vent tube are out of whack.
Old Dec 10, 2012 | 04:16 PM
lance25's Avatar
lance25
Default Air in the gas tank.
The only vent tube coming from the gas tank is connected to the charcoal filter canister, I blew the line with compress air into the tank it looks clear cuz I can hear the air blowing out to gas filler. also check the vent valve and clean it out. That is why I think the charcoal canister is the culprit. It just too bad cannot find an after market. I guess next step get one from the Dodge Stealer.
Old Dec 10, 2012 | 04:28 PM
SEAL's Avatar
SEAL
The vent tube I am talking about is the metal line that runs alongside the fill tube. It connects the top of the tank to the top of the fill tube. It allows air to vent out the top of the tank to above the fuel nozzle when you are putting the gas in. If it is plugged you will have a very hard time putting gas in your tank, especially at high flow rates. Gas station nozzles can cause this but only if their own little vent tube inside the nozzle is bad.
