1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
My '90 D150 build thread.............
Old Jul 13, 2015 | 03:54 PM
  #21
KevenP's Avatar
KevenP
Well, the 360 just wasn't enough motor for me.
I picked up a rebuilt 1968 383. Low mileage, 30 over. 9.2:1 pistons.
Plans include:
Edelbrock Performer intake
Holley 750 (or larger)
Headers
Lunati 292/480 cam
Electronic distributor.
Hoping to eek 400 hp out of it.
Old Aug 8, 2015 | 11:57 PM
  #22
KevenP's Avatar
KevenP
I ended up with an 870 Holley.
The compression will be about 9.8:1.
I bought a slightly bigger cam. Going with the
Lunati Voodoo 268/276 .494/.513.
Swapped out the 8 1/4 for a 9 1/4. Needs a
Sure Grip.
Old Aug 23, 2015 | 10:48 AM
  #23
Mr onetwo's Avatar
Mr onetwo
Sweet looking truck...I love that purple. I have a '68 Newport with the 383. Please keep us up to date on the motor build.
Old Aug 23, 2015 | 10:51 AM
  #24
Mr onetwo's Avatar
Mr onetwo
Try finding a 8 3/4" 742 case suregrip out of a 69-72 C-body... I believe it's the right width and a much better rearend. You will need different axles though (different bolt pattern).
Old Aug 31, 2015 | 12:44 PM
  #25
KevenP's Avatar
KevenP
Will do. The 906 heads are having the bowls opened and ports matched.
Too much work for the 8 3/4. I checked into it.
A complete (drum to drum) 9 1/4 cost me $300.
Old Oct 6, 2015 | 08:42 PM
  #26
KevenP's Avatar
KevenP
A little progress.
The stainless steel block hugger headers hit
the frame rail on both sides. Time for some
long tubes I guess.
Old Oct 8, 2015 | 01:45 AM
  #27
LowNSloan86's Avatar
LowNSloan86
nice build!!! that color is gorgeous. I've got an '85 thats getting a built 318 with the edelbrock performer and carter AFB 600. was wondering if you could help me with trying to do a wire declutter/tuck. i've been trying to figure out what i can remove and what i can't.
Old Oct 9, 2015 | 12:24 AM
  #28
KevenP's Avatar
KevenP
Thanks! I've tried to let the color grow on me, but I don't like it.
It should have been painted Plum Crazy.
I cut open my wire harness for the engine and just removed what I didn't need. Bundle the extras up and hide them.
What rear end are you using? If you get over 400 hp you might think about an 8 3/4 or 9 1/4.
Old Oct 9, 2015 | 12:28 AM
  #29
KevenP's Avatar
KevenP
Busted out the angle grinder and made the block huggers fit.
Now I have spark plug and wire fitment issues.
Autolite 2974's are supposed to take care of the plugs.I'll need to make some custom wires.
Old Oct 9, 2015 | 07:42 PM
  #30
Moparite's Avatar
Moparite
I would suggest ceramic boot plug wires. The heat off(#4 cylinder) header destroys the boots.
