1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have a 92 Ram D250 Diesel (78K original)when I am at idle after driving the oil pressure is dropping to L and the oil lamp light is coming on. As long as I am on the gas the pressure maintains. Also the engine (diesel) knocks more when at idle. Any suggestions are greatly appreciated.
Low oil? btw, low oil pressure is one of the worst possible things for a diesel engine. Get it checked asap, or you'll have a nice piston sized hole in the side of it.
Post this in teh Cummins section. there are diesel mechanics there. And uhhh if you have not already voted for truck of the month, I am running and can use the support [sm=americanasmiley.gif][sm=goodidea.gif][sm=Flahssssss.gif][sm=hia.gif][sm=partyparty.gif]. of course if you like the other trucks better you can vote for them as well.[sm=nothatway.gif][sm=smiley21.gif]
