A Hemi Power Ram project..HELP!!!
Old Sep 17, 2007 | 11:22 PM
JohnWaynesMopar's Avatar
JohnWaynesMopar
Default A Hemi Power Ram project..HELP!!!
hey all,
Working on a project here...a 1990 Power Ram with a 5.7 liter Hemi. I stripped it down to frame, durlined it and began rebuilding. I modified the engine mounts to accept an 04 5.7 Hemi. Now the problem...The freaking transfer case is one the wrong side. On the 1990 the transfer case goes to passenger side, while in 04 ram it goes to drivers side...What do I do now? can I just spin the transfer case 180 degrees and bolt it back down? or will the transfer case from my 1990 fit this tranny? please help...I made a huge mistake without checking this out first.
[/align]
Old Sep 19, 2007 | 02:33 PM
HellaciousHemi's Avatar
HellaciousHemi
Default RE: A Hemi Power Ram project..HELP!!!
Try looking for a axle with the pumpkin on the drivers side then.
Old Sep 20, 2007 | 06:15 AM
Jacob1's Avatar
Jacob1
You should actually be able to flip it if your really just turning the output shaft towards as differnt side. The mounting will be differnt because you flipped it.
Old Nov 3, 2009 | 07:08 PM
HUTNTRK's Avatar
HUTNTRK
Default Hemi help
wonder how the swap turned out if it did
I have a 1990 standard cab 4x4 PU and am thinking of a 5.7 swap
Thanks
Old Mar 12, 2012 | 03:39 AM
MurrayOA5599's Avatar
MurrayOA5599
does anybody know if its possible to do an engine swap with a 2WD '90 ram? I would take the stock 318 out and put in a 5.7 hemi. I'm not sure if the truck being 2WD would make a significant difference or not. Thanks
Old Mar 12, 2012 | 11:27 AM
SEAL's Avatar
SEAL
Anything is possible. The difference between a 2WD and a 4WD is that there are a few less problems to deal with on the 2WD.
