83' D-150 sits to low
Old Nov 19, 2007 | 12:33 AM
Aaron859's Avatar
Aaron859
Default 83' D-150 sits to low
my 1983 D-150 sits a little to low, I'd like to lift it a few inches ( dont know how many for sure ) any recommendations for lift kits or any adivce would be useful
heres a pic http://img518.imageshack.us/img518/9...8f6410alr3.jpg
Old Nov 19, 2007 | 09:39 AM
PushnFords's Avatar
PushnFords
Default RE: 83' D-150 sits to low
I'm guessing the D150 has a coil spring front suspension. If so, they make spacers that go under the coil spring. If I remember right a 1/4" spacer is supposed to lift the vehicle 1" but it has been several years...might not remember that right. Here is what they look like:
http://cgi.ebay.com/ebaymotors/S10-S...em220170708265
For your Dodge you might need to measure the diameter of your coil springs and check around. Use lift blocks for the rear.
Derek
Old Nov 19, 2007 | 08:37 PM
Jacob1's Avatar
Jacob1
Looks as if you have a broken spring or weak ones. Look at thise if you haven't already.
Old Nov 20, 2007 | 11:04 PM
Aaron859's Avatar
Aaron859
allright i looked up some lift blocks, how would you install those? Do they go under the leaf springs or what?
