Mechanical fuel pump on 88 w100
Subscribe
Dec 1, 2007 | 07:29 PM
I want to convert my 88 from TBI to carburated and I was just wondering if I can put a mechanical pump on it. I notice that there is a block off plate on the block where the pump would go, but I was just wondering if the EFI trucks had a lobe on the cam to drivea mechanical pump.And will the stock cam even run with a carb?
Reply 0
Dec 2, 2007 | 12:03 PM
RE: Mechanical fuel pump on 88 w100
I would use the pump that is currently running your injectors. The pressure will be to high so you will need a pressure regulator. The chances that there is a fuel pump eccentric on your fuel injected motor is very slim so that means you will have to pull the timing chain cover and install one to use a mech. pump.
Reply 0
Dec 2, 2007 | 01:08 PM
I plan on doing a cam swap later, so that may become an option. But for now I think maybe your right.
Reply 0
Dec 4, 2007 | 04:51 PM
I recommend a bypass regulator so you don't burnup the pump.You still could have a eccentric in there,the cam will run ok.
Remember this is a computer controlled motor so your computer will be confused and may play havoc with your timing.
Reply 0
Dec 4, 2007 | 07:39 PM
The computer is going bye-bye. I`m going to rewire the whole truck.
Reply 0
Subscribe
