egr
your ignition timing is already advanced to compensate for the EGR
and if you remove it you may need to use higher octane
when in the 40 to 80% open throttle range.
EGR is not used at full throttle, so no effect on maximum horsepower
If your sparkplugs and ignition is in good shape
EGR improves MPG.
If your sparkplugs and ignition has a problem
EGR increases mis-fires and decreases MPG.
EGR improves MPG.
