89' power ram running rough
Old Dec 9, 2007 | 05:06 PM
power ram's Avatar
power ram
Default 89' power ram running rough
The truck runs roughish when i first start it up. After it warms up its quiet and purrrs
Im going to replace plugs, wires, cap and rotor. and check the timing. Anything else I should I check??
Old Dec 10, 2007 | 10:10 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: 89' power ram running rough
replace the fuel filter, check the fuel pump for proper pressure. also look at all the rubber fuel lines. if they are old as the truck, they may seap fuel/ preassure but not be cracked. whta happens, it the rubber expands like a balloon and reduces your available pressure.
