springs
Old Dec 16, 2007 | 10:01 PM
jayme568's Avatar
jayme568
Default springs
I have an 88 d150 2wd truck. The front sits a little lop sided ( lower on the driver side) and the only thing i can come up with is worn springs, more so on that one side. So, pending my computer that comes on tuesday fixes the motor problems, i start the next few projects. Any recomendations on springs or suggestions? Front coil springs that is. The shock towers are fine and the shocks themselves are brand new. Thanks for your help.
Old Dec 16, 2007 | 11:36 PM
moparborn's Avatar
moparborn
Default RE: springs
I got my springs at airbagit.com
Old Dec 17, 2007 | 10:01 AM
PushnFords's Avatar
PushnFords
Default RE: springs
I'm not a really big fan of replacement springs because most I've dealt with don't have the right spring rates, are too soft, sit too high, etc. If you are trying to change the height then you don't have any choice. If you want the stock height and just want it to sit level, look into some spring spacers. There are little horseshoe shaped pieces that sit under your spring. Something like 1/8" spacer changes the vehicle height 1/4". If you do want to get new springs I've had good luck with http://www.eatonsprings.com/
Derek
