Wiring Schematic.. wiring prolbem
Old Jan 5, 2008 | 09:35 PM
moosenbabe's Avatar
moosenbabe
Default Wiring Schematic.. wiring prolbem
Hi...
I have a 1992 3/4 Ton, Dodge Cummins Diesel.. 4X4
I need a wiring Schematic... The prolbem I am having is the alternator was not charging, so I replaced it, and put new battery terminals on it. Relay on driver side fender clicks several times when you turn the igniton on, and wait for the wait to start light and others to go out. But the relay that is clicking is for the fuel pump and auto-shutdown. Tach is also jumpingat around500 rpms, when truck isnt even running. When I turned the head lights on, without truck running, the tach went back to zero. Any advice would be welcome. Thanks
Old Jan 5, 2008 | 10:01 PM
Nofrag's Avatar
Nofrag
Default RE: Wiring Schematic.. wiring prolbem
http://www.autozone.com/ has repair giudes with wiring schematics for that truck.
Old Jan 6, 2008 | 04:21 PM
Jacob1's Avatar
Jacob1
My relays were ticking but it stopped my truck from even starting. Gas engine though. The crank sensor wire rubbed bald and shorted computer. I doubt this is your problem though, being two different engine.
