2002 4.7 OIL PRESSURE
Old Jan 7, 2008 | 10:58 AM
FLASHJR's Avatar
FLASHJR
Default 2002 4.7 OIL PRESSURE
Hi I'm new to this and have a 2002 ram 1500 quad cab 4x4 the oil pressure gauge drops to nothing and the check gauge light comes on. this is only at low rpms. When I get going again it goes back up. Has anyone had this problem and how do I fix it?
Thanks
Old Jan 7, 2008 | 12:20 PM
racer9's Avatar
racer9
Default RE: 2002 4.7 OIL PRESSURE
It's probably the oil pressure sender, possibly just a loose wire, but you need to get a mechanical gauge on it to be sure.
Also, you're posting in the First Generation forum, which isyears '81 to '93. You want to post in 2nd generation, which is '94 to '02. '03 to '06 is 3rd gen and '07 up is 4th gen.
