Noob with troubles
Old Feb 10, 2008 | 12:18 AM
rezachi's Avatar
rezachi
Default RE: Noob with troubles
ike I'm starting to think it's not the linkages, b/c when I'm going, if I push the gas more, the truck acts like it's bogging down, so the linkages have to be moving, right?
I want to test the coil, but I can't seem to find what the primary and secondary resistances are supposed to be (autozone's website has tons of service manual stuff on it, but the page I need with the specifications for the electrical ignition is down; go figure), does anybody know them?
Oh, and that's an awesome looking truck moparborn.
Old Feb 10, 2008 | 01:06 AM
moparborn's Avatar
moparborn
Thank you.
Its starting to sound like carburation,sounds like its running on just the idle/low speed curcuit,possibly something clogging the high speedcurcuit and not letting the fuel through.Maybe try spraying carb cleaner around the carb area to make sure you do not have any other vacuum leaks.Might be time to rebuild the carb.
A quick coil test,use insulated pliers or? and hold the secondary wire a 1/4 inch from ground,should be a nice strong spark,increase the distance slowly to about 3/4 inch,if it is still sparking there and not across the coil terminals the coil should be ok.
