NO Low Beams on 89 Ram
Lost the low beams tonight on my 89 ram. High beams work fine as does all the other lights. Checked both bulbs and they are fine. Where should I look next. So dam cold up here want to try to hit the obvious first.
I cannot see any fuse in the headlight circuit. IS there??
I have another high/low switch for the column but would the headlight switch be a more likely target area. Any plugs under the hood I should look at. It is a 4X4 and they talk about a plow block in the manual for adding lights but I don't know where that is.Is the headlight switch out of a 86 the same??
Your help is greatly appreciated
