lowering kit for 72-93 2wd
Old Mar 15, 2008 | 10:52 PM
4406rr's Avatar
4406rr
Default lowering kit for 72-93 2wd
We are selling a complete kit to lower the 72-93 half ton Dodge truck and Ramcharger 4" front 6" rear $819.99 + shipping add $20.00 for powder coated arms
parts are also available individually +shipping
boxed-bucket lower control arms with ball joints $545.00 add $20.00 for powder coated arms
springs (1.5 coils shorter than stock $85.00
front shocks (they will not bottom out) $22.00
rear shocks (they will not bottom out) $45.00
shock plates-mounts $50.00
spring perches (must be welded to the rear housing) $25.00
u-bolts all 4 $25.00
stock length springs also available for a 2" drop front $75.00
installation at our shop $450.00
the rear is a flip. It puts the rear on top of the leaf spring. No cutting required to the frame in the rear.
In the front we use a bucket style lower control arm and shorter springs.
The bump stops must be shortened or removed in the front which is the only cutting you need to do.
also fiberglass interior trim molded off of nos 93 plastic interior parts coming soon. put the 1993 LE interior in any 1972-1993 truck
We are located near St. Louis in Wood River IL. For installation and ordering
contact Eric at Mid America Customs 618-407-7374 or eric@midamericacustoms.com
midamericacustoms.com under construction
http://img.photobucket.com/albums/v3...3/c7374b0e.jpg
midamericacustoms.com lowering kit for the 72-93 dodge ram and ram charger coming soon interior kits for 72-93 ram
Old Mar 24, 2008 | 08:16 PM
84 Ram's Avatar
84 Ram
Default RE: lowering kit for 72-93 2wd
I ordered a set of the drop control arms they should be here sometime this week[sm=bounceybounce.gif]
Old Mar 25, 2008 | 03:12 PM
turbododgepirate's Avatar
turbododgepirate
Eric, I sent money 3-14-2008, and I know I owe you more for shipping. I just haven't heard from you, so I figured I would ask.
Old Mar 26, 2008 | 12:16 AM
4406rr's Avatar
4406rr
I shipped it. I think it was the 20th or 21st. shipping was 15.00
Old Mar 26, 2008 | 10:13 AM
turbododgepirate
Yes, Thanks for the PM and post!!! I'll send you the additional money immediately!! EXCELLENT communication! Probably the best by any vendor I have used to date!
It showed up today!!
Old Mar 31, 2008 | 01:45 PM
4406rr's Avatar
4406rr
here are 84rams lower arms I just need to press in the ball joints
Old Mar 31, 2008 | 02:23 PM
nemesis_SS's Avatar
nemesis_SS
do you makes these fom scratch? what gauge steel are they?
