93 ram front clip
Old Mar 22, 2008 | 11:12 PM
cggas's Avatar
cggas
Default 93 ram front clip
i have a 92 ram 4x4, i am replacing the front clip with an 93 ram clip. my question is the core supports are a little diffrent when it comes to the way the radiator mounts. is there a quick fix so i can use my 92 radiator in the 93 core support??the 93 was a diesel. is there any other problems i am going to run into swaping front ends??thanks chris
Old Mar 23, 2008 | 12:40 PM
nemesis_SS's Avatar
nemesis_SS
Default RE: 93 ram front clip
i dont have a solution, but if you're gonna be fabbing around the radthen you should think about putting in an electric fan. theyre cheap if your just buying the fan, whithout the whoel housing and everything.
