95 Clutch problem
Old Apr 3, 2008 | 10:44 AM
mrbuff754's Avatar
mrbuff754
Default 95 Clutch problem
Hey, I just bought a 1995 dodge Dakota 2.5 2wd 5 speed. The clutch won’t disengage. I push in the clutch and turn the key and it cranks over while the truck jumps forward and then starts and goes. Or I can start it in N and I can’t get it in to gear.
I have the dodge shop manual and it doesn’t say how to bleed the system, it just says replace parts. Also I don’t see a bleed on the slave.
So my question is, how do I bleed it or adjust it? Or what is wrong?
Thanks Nick
Old Apr 4, 2008 | 12:53 PM
kurts2's Avatar
kurts2
Default RE: 95 Clutch problem
I once had a "chatter spring" break off and lodge between the presure plate and clutch...that made it "always engaged."
