1990 dodge ram d250, charging issues?
sometimes it charges sometimes it dont, i had the alt ck it was good, they say that the smec is bad, it has the reg, built in, i dont know, sometime it throws a code of 41, it done this when i stoped quick at one time, and when i started the truck and let off the key to quick, and it didnt start, ck eng light came on...
hey code 41 is "generator field not switching properly" which i had oncewhen i left the lights on anmy battery died. I charged the battery and never had the problem again.which means this code -could- be unrelated to yournon charging issue, but it probably is
yourfield driver circuitmight beshorted
or maybea PCM failure, though i dont think
good luck
good luck
they did say the batt was low,maybe i should charge it...its starts up fast, what about the smec they also said that has the reg built in the unit, its a 90 amp 2 pulley Chrysler alt...
