idles fine, push acc. pedal then it stalls
Old May 4, 2008 | 08:01 AM
  #21
power ram's Avatar
power ram
Default RE: idles fine, push acc. pedal then it stalls-Update!!!!!!
yeah the reg was hooked up to the manifold vacuum source. When I pulled the hose there wasnt any fuel in it. Bone dry.
I havent started it up and see if it corrected the problem, due to I have the dash face apart to install a radio.
Old May 4, 2008 | 05:20 PM
  #22
power ram's Avatar
power ram
Well i drove up to 20 mph in the yard and it runs 100 percent better didnt stall once!!!
I am going to put in new injectors, o2 sensor, new pvc valve, new valve covers/gaskets. Then im going to put the computer on it and see what else needs replacing.
Thanks again to all that helped me get my power ram rolling.
Old May 4, 2008 | 09:16 PM
  #23
nemesis_SS's Avatar
nemesis_SS
hey i posted a little DIY how to on changing the valve cover gaskets. If you have a smog pump on your engine, be sure tounhook it from the manifold, which i didnt do. It has a bracket on the end which bolts into the manifold, and when ipriedthe smog pump line out of the way to reomve/insert the covers i broke it off - leaving the bolt inside the manifold and a big holewhere the smog pumpline would have gone in. Anyhow while repairing that i didnt learn my lesson and moved the pipe around so much that i snapped it off the manifold on the other side. Big freaking mess.
