Timing Info
Old Sep 1, 2008 | 06:34 PM
rich19732008's Avatar
rich19732008
New Member
Exclamation Timing Info
I have a 1988 dodge ram le 150 pick up and I NEED TO FIND OUT HOW TO SET THE TIMING FOR IT
Old Sep 1, 2008 | 06:56 PM
rich19732008
New Member
Exclamation okay its not the timing
1988 dodge le150 problem is it starts and stays running until I hit the gas and then it stalls out I changed the distrubuter cap and the throttle position censor and checked the egr valve and it still stalls. any info would be greatly appreciated
Old Sep 1, 2008 | 08:40 PM
lugnuts's Avatar
lugnuts
To set the timing warm up the mtr. then kill it. Unplug the temp sensor,set the timing,kill it plug the sensor in.
Possibles on the stall- fuel supply/pressure [first], one or both injectors plugged/ one not working [next],then map sensor/vacuum to it,egr controls[not likely],totally plugged exhaust, intermittent connection opened by engine movement[seen it before], computer fried. Those are the most likely.
Pull the + cable to clear the memory,then run it a few minutes and make it stall. Turn the key on/off/on/off/on/off/on. Watch the check engine light,count the flashes. 1 long 2 short= code 12 etc. Code 55 is battery disconnected,means nothing.
You didn't say whether it runs like crap or smooth at idle,or only dies in gear/under load. Engine warm/cold?[ie open/closed loop] Black smoke/plugs black or white? Hot spark? Bring up rpm slowly,start to stumble/miss, or bog or just instantly die? A scanner is almost a must have on computer controls to watch for lean/rich, block learn values [tells what the computer is doing with the fuel ratio over time]or unresponsive/out of range sensors, or to eliminate the basic system as the cause.
Old Sep 1, 2008 | 09:20 PM
power ram's Avatar
power ram
might also be the o2 sensor. Thats what ended up being my problem. Yes those computers are good to have helps figure out the problem.
Old Sep 5, 2008 | 11:14 PM
oldmopie's Avatar
oldmopie
check your fuel pressure regulator
