Dakota differentials strong enough....?
Old Sep 19, 2008 | 08:21 PM
racer9's Avatar
racer9
Default Dakota differentials strong enough....?
I'm considering which suspension parts to use for my truck. I'm putting a 4cyl Cummins in, and need a stronger rear than came with the stock 225ci. The Cummins is 120hp, and about 250 ft/lbs torque, stock, for now.
I'm thinking Ford 9", very strong and plenty of parts, or getting a wreck/rustout Dakota, and using the rear from it.
I'm also planning to use the rack and pinion from a Dak, and possibly other front parts. Another consideration is wheel availability.
I want the front and rear bolt patterns to match, to make it easier to find wheels.
So is the Dak rear stout enough?
Old Sep 20, 2008 | 03:14 PM
nemesis_SS's Avatar
nemesis_SS
they were available with the magnum 5.2 (230hp) so i dont see why not from the engine side of things. but the ram is a lot heavier....maybe 1000 or 1500 pounds heavier. So im not sure.
Old Sep 20, 2008 | 08:05 PM
lugnuts's Avatar
lugnuts
I ran slicks and a 440 through the stock early 8 1/4 {small}under my 84 for a short while before it grenaded in spectacular fashion. Unless it's geared too deep for the deisel I'd think the stock rear would live.
The updated {big}8 1/4 seems to handle medium off road abuse OK under my Ramcharger. How about one from under a Ram? 3.21 gears for the deisels' rpms? Be a bolt in deal,and the front rotors swap too if needed.
The 318/360 Daks came with big 8 1/4s so yeah it's stout enough if that's the way you want to go.
Old Sep 20, 2008 | 11:21 PM
racer9's Avatar
racer9
I'd love to find a 3:21 geared posi rear, from a Ram, or anything.
