bed removal/flatbed
Old Oct 27, 2008 | 04:50 PM
power ram's Avatar
power ram
Default bed removal/flatbed
Im thinking about removing the bowed rusted bed of my w100 and building a flat bed.
Would I weld some angle steel on the frame in a rectangle, then I was thinking on 3" thick pressure treated lumber for the top and just bolt it to the angle steel. Is that how its done?
Old Oct 27, 2008 | 06:58 PM
racer9's Avatar
racer9
When I built mine, I made the bed frame mounts match up with the oem mounts, I just welded a short piece of angle iron on the the bed rail and drilled a hole in it, and welded a nut to it, so I could bolt it to the same holes in the truck frame mounts. I ended up putting a 2X4 under it later, just had to get longer bolts and drill out the 2X4.
Old Oct 28, 2008 | 11:04 PM
nemesis_SS's Avatar
nemesis_SS
if you remove that bed id put it up for sale here. somebody might need it (or if the tailgate is clean just that)
