electrical ignition problem
Old Nov 26, 2008 | 12:29 AM
dodgeboy1984's Avatar
dodgeboy1984
Default narrowing it down
Ok guys it was not the resistor or the ignition switch. I think i may have figured it out the ecu harness is not hooked up properly. I bought a Chiltons manuel and it does not go into detail about the ecu wiring harness. What i belive I need is a pin out diagram for the ecu so i can wire the ecu plug properly. Does any of you guys have one or the same year of truck that they can copy down what wire goes into what termanil.
