carb questions????
Old Dec 23, 2008 | 11:08 PM
dasaroth's Avatar
dasaroth
Default carb questions????
Ok, so i was working on the old dodge yesterday, changed the oil, air cleaner and the gas filter (gas filter was semi clogged). So Today i went out to start the dodge (very cold this morning) pressed the pedal once to set the choke fired almost instantly. but i noticed a little gas smell that wasn't there before. so i was walking around the truck and smelled the exhaust and shes running super rich (but not to the point its smoking black). even when she warms up there still is a gas smell coming from it,and is harder to start like its getting flooded.so the question is, is there a way to adjust the carb. i took a quick glance at it and i saw no adjustment screws other than idle, it has what looks like little square blocks where the adjustment screws should be. or should i just say screw the carb, i got a holley street avenger 750cfm carb stashed in the garage and put that on it. do you think it may be too much for the old 318. oyeah its a 87 d250 318 2wd auto if you all forgot.
Old Dec 23, 2008 | 11:24 PM
moparborn's Avatar
moparborn
It is more than enough,but with some adjusting it should be ok.
You can remove the plugs on the stock carb while doing a rebuild,if the filter was clogging up,some debris may have gotten in the carb.
