Transmssion Swap - 727 Out - NP435 In
Old Dec 26, 2008 | 04:33 PM
dws35's Avatar
dws35
Default Transmssion Swap - 727 Out - NP435 In
Looking to swap 727 auto trans out of 1976 Power Wagon (with 400 V-8) and replace it with NP435 4 speed. Looking for any info on this swap, as well as a source for parts.
Ideally would likely to obtain a junked out truck to get all required parts.
Thanks
Dan
Old Dec 26, 2008 | 10:07 PM
lugnuts's Avatar
lugnuts
First problem to watch for is the lack of a finished pilot bushing hole in the crank. 90% weren't drilled by the mid 70s. A 400 with the finished to size pilot bushing hole is even more scarce. A bushing that fits the register where the torque converter hub goes used to be available,not sure if it still is. May require shortening the input shaft journal a little to keep it from bottoming in the crank. A machine shop can build you a bushing,easier than pulling the crank and having it drilled.
For just about any trans/tranfer case swap you can dream up it's probably here: http://www.ramchargercentral.com Old site, lotsa info.
Old Jan 6, 2009 | 07:43 PM
500gtsteve's Avatar
500gtsteve
Default 4 speed swap
Man Im looking to do the same thing, except I dont want the 4 speed I want an automatic........................................
Thanks
Dan
Old Jan 16, 2009 | 09:04 PM
dws35's Avatar
dws35
If you have a 400 auto 4x4 and are lookin to get rid of the 4 speed and want and auto please email.
Thx
dws35@comcast.net
Old Jan 17, 2009 | 08:24 AM
500gtsteve's Avatar
500gtsteve
Thx
dws35@comcast.net
No I have 360, I wish it was a big block............
