installing mechanical gauges
Old Jan 7, 2009 | 06:09 PM
eclancy's Avatar
eclancy
Default installing mechanical gauges
where are we tapping into the engine for oil pressure readings for a mechanical oil pressure gauge?
where are we tapping into to get coolant temp readings for a similar mechanical gauge?
'93 w150, magnum 318
I'm having some low oil pressure issues, but at only 70kmi, i doubt the engine is worn, and i am leaning towards a bad electric sender.
Thanks in advance.
Old Jan 7, 2009 | 06:39 PM
charlie1935's Avatar
charlie1935
If you want to keep the stock oil pressure gauge too use a tee fitting into the block. Don't know about the temp. gauge.
Old Jan 8, 2009 | 07:14 PM
eclancy's Avatar
eclancy
so the only place to tap for oil pressure is where the factory sender is? i really dont cre if the factory one works or not.
any other ideas on the coolant temp probe?
