T.A. Performance rear end girdles?
Old Jan 21, 2009 | 12:38 AM
basdas's Avatar
basdas
Default T.A. Performance rear end girdles?
My 93 w-250 is used for hauling heavy loads it has a high gvw rating.
Question is the aluminum girdles from t.a. performance would be good for my application? I like the idea that it ties the diff 2 bolts to the cover bolts with x-tra oil capacity.
I know there are other diff covers out there but this is the only girdle I know of.
Thanks
Brett
Old Jan 21, 2009 | 07:05 AM
lugnuts's Avatar
lugnuts
Cap girdles are a good way to help ring gear deflection,but the rear axle under your 250 is a pretty beefy peice anyway. Having troubles burning up ring and pinions?
Old Jan 21, 2009 | 12:14 PM
basdas's Avatar
basdas
no I am not burning up the diff I want to prevent any problems. I just figured x-tra strength pluss x-tra oil would be helpful.
I know 4 wheel parts have some but none connect to the two diff bolt and to the cover bolts.
