A couple questions
Old Mar 11, 2009 | 07:25 PM
bbrian4485's Avatar
bbrian4485
Default A couple questions
First;
I don't have any bright lights on my 1991 dakota club cab, I have changed out my lights and still nothing.
second;
I am looking for a camper shell. as long as I find one from the first generation 89' to 95' it should work as long as it is a club cab right?
Old Mar 11, 2009 | 07:31 PM
lugnuts's Avatar
lugnuts
Probably the dimmer switch, can't say on the camper shell. As long as the bed's the same length as the shell I'd think so.
Old Mar 12, 2009 | 05:19 AM
83dodgeswb4x4's Avatar
83dodgeswb4x4
If I read your second question correctly, you are asking if you can put a topper from a full size on your dakota, correct? I'm pretty sure the dakota is narrower then the full size. Unless the Dakotas are classidied by generations as well, then please disreguard this post. And also it doesn't matter if it came off a club cab or not. There are only two bed sizes. short and long. As for you light problem, I am not sure about the Dakota, but I know the full size are natorious for the light switches going bad.
